Looks like it has been repaired multiple times. I'd grind all the old welds flat and run a downhand 6010 in the groove you ground. 6010 is the best if there's any rust or other crap in the steel.
99 holes is this tank I'm repairing, 99 holes is this tankI'm wondering how many holes I could blow into that with my 1/8 7018 stick rod.
Solid wire Mig is notorious for cold lap with inexperienced welders. It's the reason Lincoln was so late getting into Mig. The weld looks great but there's no fusion under it on 1 side of the joint. You see it on cheaply made implements and stuff out of China. Some people think 6010 is a bad rod because it has more spatter and is rough looking. It was never meant to be super smooth but if you look at a pipeline welded with it, it's a work of art. That's where the term stack of dimes comes from.As a general rule 6010/6011 is a rare welding rod in Australia, much like 7018.
If you go into a welding shop for electrodes you generally have a choice of 6013 or 7016. You can get everything else, it is just not common.
I have not really understood the love for either of those rods. After some years of being on the internet are reading all about this magical 6010 rod (after many years of only using 6013 on a piddly little home transformer welder) I ended up with a small Miller engine welder and got a packet of 6010 rods. They really were handy things to have and I really liked them. I would call them the farmers friend, far better then 6013 or 6012. Some dirty greased filled broken part. We all know what farmers are like. Half a grind if you are lucky, and start welding, then add more weld for good luck, and then a bit more just in case.
These days I see flux core mig everywhere on farms, and I think it has lowered welding skills, there are crap highly porous welds galore. At least with a stick a crap weld looked crap, while a crap MIG weld can look half decent and be worse then the crap stick weld.
I don't like leaking gas tanks or hyd. tanks. Gas tanks because they can blow up and hyd. tanks or any oil tanks because the oil gets into steel. You have burn it out and sometimes it still messes with the weld. Diesel tanks aren't too bad but are mostly aluminum. I've only ever welded a couple for a guy I know with a couple trucks. However I know a guy who has a thriving business repairing and making new aluminum diesel tanks. He also makes special awards like silver and bronze hockey sticks for the NHL. He is the original silver stick maker although some idiot in Ontario claims to be. They are solid polished stainless steel. He made a very special one for Barrack Obama that the Stanley Cup winners presented to him when they were invited to the White House. He has a couple pics. of Obama admiring it. It's pretty cool but I couldn't make out everything engraved on it. A few years he one waiting to be picked up. They are pretty heavy and exact copies of the players game stick. He gets a game stick supplied to copy it.Hey, we have two water truck threads happening. That’s awesome. I love anything with a leaky tank.
Water Truck Chassis
What's everyones favorite chassis for a tandem axel water truck? And Why? Everything we currently have is Freightliner, but I am always open to new thoughts. https://watertrucksupply.com/www.heavyequipmentforums.com
