Cost to repaint/recondition excavator
Texas
Any have some post experience with this? I've got 2007 Kobelco 210LC with practically brand new undercarriage, partially reconditioned motor, total hours are 5500. Very good running machine. Just curious as to what cost to bring it back to life. New paint, some new sheet metal(dents) and some upholstery. Probably new seat. I'm out of Houston Texas. Thanks
Welcome to the Forums Nathan! Glad to have you.
What do plan on doing with the machine? A 2007 with 5500 hours is going to be tough recoup the money spent to repaint with today's cost.
Seat's are not that complicated, a local upholstery shop can do that including the foam just need to provide them the metal pan of the seat.
Sheet metal outside of a junk yard will be very expensive and finding "unbent" panels in a junkyard on a 14 year old machine is a needle in a hay stack. Might want to find a local sheet metal/fab shop that can make some new panels.
As far as the paint goes rattle cans work for us however we bring our machines in at least once a year to beat out dents, weld, bondo and touch up paint in order to keep them presentable. Rattle canning an entire machine is not something I would suggest.:p
cosmaar1
Ohio
Personally speaking, your money would be better spent fixing hoses, changing fluids, etc.
If I had to guess, you are probably looking at 15-20k if not more. Lot of man hours for pressure washing, degreasing, removing hoses and reinstalling, painting, supplies, etc.
skata
midwest
Doing a spray job will be a lot of work. A lot of prep work. And covering and taping.
If you want easier, maybe roll the paint on. Use fine foam rollers which give a pretty smooth finish. Last couple machines I painted, I used Sherwin-Williams Hi-solids polyurethane, which you can spray or roll.
Just make sure you clean and degrease the old paint good. Try to sand and prime any rust with a spray can.
Texas
Instead of it being a $40k machine due to its current appeal, I believe it would be back around $60k or better after the revamp. I take pride in my equipment, mechanically, and appearance. Oil and gas industry rather new equipment on the job. So I'm trying to have this thing looking it's best.
Texas
Kind of an idea of the shape.
suladas
You could do a half decent job for little cost. Seems in decent shape just faded paint. Bondo/pull dents and just tape off things like hoses, etc. And if it's purely for looks you can save a fair amount of effort skipping areas like top of boom etc. I am planning to do my Volvo 210 this winter boom is fine I just want to fix a few dents in panels and repaint counterweight. It's amazing how much difference a few days work and few hundred bucks in paint will make.
If you're expecting to make a $40k machine a $60k machine though I doubt a paint job will do it and to have any hope of increasing that kind of value the paint job would have to look like new which will cost you hundreds of hours of labor. Based on your pictures, that machine looks decent I doubt it will increase value much. Maybe $5k if you did a fairly decent job?
Texas
I'm not trying to buy, paint, sell like all the other crooks I've dealt with over the years. I just know how good of shape (mechanically) this machine is in and Instead of having to buy a new machine to be brought into a oil/gas facility. I want to repaint, re-upholster mine so that it looks new. So the questions won't be raised by reps on the condition of the machines I'm bringing on locations.
terex herder
Kansas
You are trying to put lipstick on a pig. After you get the lipstick applied, it's still a pig.
First thing that will happen after you spend the long dollars on a new paint job is you will have the opportunity to buy a much newer hoe for a reasonable price. You will sell your old hoe for less money than it was worth before the paint job.
But redo the seat. Your ass will thank you every day.
Texas
I like to think of my ol'girl as a brunette after a long night out. She's ruffed up but all she needs is a little "lipstick" to get back right! Lol
Kobelco ireland
Ireland
Mechanic
If your planning on keeping it then paint it, it will make you love it again. I work on a few of that model with Well over 20000 hours. A few of my costumers traded in really good machines cos they were getting old and looked a little rough. Now they own really pretty machines that are brokedown every few weeks with emissions problem.
Kobelco ireland
Ireland
Mechanic
Not sure about pricing over there but a costumer painted his machine last year. He fitted two new rear door panels 1100 euros each from dealer. Repainted whole machine from new Holland yellow to kobelco blue Inc. all new decals for 4500 euros. The machine looked brand new afterwards
terex herder
Kansas
I don't know about the oilfield, but around here none of the pipeline outfits own any iron. They just bring hands and tools, and have United Rentals, Cat, or some other house deliver and pick up the iron.
Texas
Alot I know of own a few and rent a bunch like you're saying.
suladas
All I know is when I see fresh paint on an old machine, I run for the hills. IMO you think by painting you are adding value as you are making it look nicer, but in reality you are making things worse off and scaring potential buyers away.
just my 2C
The good old "20-gallon overhaul" - guaranteed to generate the run as far and as fast as you can in the opposite direction reaction in most people who know equipment.
Big difference between slapping some paint on a old POS, and re-painting a good machine properly to make it look better. One is a waste of time, the other will result in increasing the machines value. If they do a good enough job, work it for a few months 99.99% of people would never know it was painted and could easily assume it was just parked inside and really looked after.
Here's one example. Pictures can be deceiving but the new paint makes the machine look a lot better and from what the pictures show, it was actually a decent job. They had a few old pictures up before, and the house is improved 100 fold.
https://www.kijiji.ca/v-heavy-equipment-machinery/calgary/2006-hitachi-200-excavator/1589422727
