An electric fan sounds like a good idea. Could possibly use one with less CFM than the original fan to let the engine be a little warmer.
Millions of cars have them.
I have to make a correction / comment on my last post.I thought in your situation that an electric fan would be a good option.
There's 8Kw of electric to tap. Lose the incandescent light bulbs, replace with LED. Now you have a 200 watts to run a fan. Though it might not be enough during the Summer. Does the generator have its own fan ?
Then an insulating blanket on the block or diverting the air from the radiator around the block (and to the generator) is in order.I am guessing that the thermostat is never opening and the engine block is acting as an unregulated radiator here though.
I'm going on the assumption that this genset is not running unattended for long periods of time, say a week or more? If the outside temp does raise to a point the reverse flow of the fan could cause a problem with reduced cooling capacity the need for heat in shop would also be reduced thereby taking some of the load off the engine.If you wanted a reverse, buy another fan. I picked up a reverse fan for my JD 350 dozer, it keeps the floorboards defrosted when running it in the winter time, had issues with ice and snow getting packed around the pedals and stuff when using it as a snowplow. I picked mine up from Jegs, they have quite the assortment.
