Hinges first. I recommend the hinges be no further than a foot from the end of the dump box. Hopefully you have enough truck frame to accomplish this. Now for your pump. If you don't plan on ever pulling a pup or having a hydraulic highlift tailgate, a pump with the control valve built in is the best. However, they come down fairly slowly. There are options to help this, a quick drop valve being one. That would require two control levers/cables/whatever. You could also use an electric over hydraulic valve like you use for side dump trailers. Best thing to do would be to get in touch with a shop that sets up dump trucks. They would be able to tell you more options on the hydraulics part. My.preference for PTO control is air-operated. They do make electric controls as well. Tailgate control is usually accomplished by a small, dual-acting air cylinder, the smaller the better (as long as it provides enough force). They do make make air open, spring close ones, but if you are ever going to spread, the spring close ones sometimes release on their own when you raise the box up. Once again, I prefer a dual acting cylinder with an 1½" bore. Nice and fast. Velvac makes a very nice air control for the cab. We had electric shakers on our dumps, they do make air ones. Air shakers are a little simpler to hook up, just some wires, a momentary switch, and an electric over air solenoid valve. An electric shaker would require a solenoid (just like the ones that use to be right by the battery to send power to the starter on older vehicles, or the glowplug solenoid on Ford diesels) to send battery voltage to the shaker. Would be operated by a momentary switch same as the air valve for an air shaker. I've never had to deal with tarps on dump trucks, so I'm not much help here. We do have electric tarps on our grain trailers, pretty expensive to have a remote control tarp though when you really wouldn't need it. I assume they make a two-way switch that can handle the amps the tarp motor requires that you would control with a three-way momentary switch in the cab. If you need more clarification on any of this, I'll be happy to explain in further detail.
