norite
Has anyone converted a 2wd backhoe to 4wd? Seems to be many 2wd backhoes for sale that go cheap compared to 4wd. I am talking older machines such as jd310,410,510 c's and d's. I am thinking of replacing the front axle with one from a wrecked/burned machine. Obviously I need the front driveshaft as well. What I need to know is whether the transmission would need to be replaced, are the 2wd/4wd transmissions different or could a 2wd trans be upgraded by installing an output shaft or pto setup from the wreck? If the entire rear transaxle needs replacing, it probably wouldn't be worth it I assume. Any ideas?
