OldandWorn
A question about leftover, slightly damaged, or used steel corrigated culvert pipe on construction jobs. I have a home project idea to store firewood that will not get off the ground unless I can find large diameter culvert pipe for free or at a reasonable cost.
I need about 20 pieces 4' long and somewhere close to 5' diameter. Is 5' a common size? 4' or 6' diameter could be used but 5' is my target size.
Are short length scraps availiable on jobs or is it cut to length at the factory? What happens to the old stuff that is dug up? What are the chances of Joe Blow off the street being able to get permission to haul the pipe away? Loading, cutting long lengths so it will fit on my 10' trailer, I'm seeing some safety issues here even if the pipe is availiable.
Thanks for your input
