Well, guys, it sounds like this project is going to happen this fall. The last permit will be in place in a couple weeks, and as soon as the ink is dry, it's going to be go time. I was never able to locate anybody to give an estimate on blasting it, so we're going to have to use brute force. I've been thinking over many scenarios this summer, and I'm down to two possibilities. First one is to break a small, narrow hole through the dam to let the water off, second is to push out a coffer dam and bury a 36" pipe to drain it off. The water is about 6' deep on the top side, so installing a pipe wouldn't be too bad. The dam itself is pretty crude. It appears they just basically "piled" a softer mud-mix, no rebar, and blanketed that to form the spillway. The blanket layer is only about 6" thick, and contains the only rebar except for the wing walls. Upon further inspection, about a third of the core under the blanket is completely gone. You can look in THROUGH the south wingwall, and it looks like a cave for about 30'. My main question is this. If I choose to break a hole to let water out, should I be worried about the wall holding the water giving away while I'm trying to break it out? My initial plan is to break up the spillway where it's eroded out underneath, and kind of fill the void in with the broken concrete, and then open the water side and let the water run through there. I'm thinking of about a 3' wide hole to start with, can a hammer be used in water past the punch part?
