Computer Failure HELP!
DD Cincy
Ohio
My Volvo has been running a little off lately. Went to start it up this morning and it said "Stop Engine...Computer Failure"
Where should I go from here?
cuttin edge
NB Canada
Finish grader operator
My Volvo grader will do that sometimes. Was told that when I start it, I have to turn the key on, let the dash cycle through, like 5 or 10 seconds then hit the starter. Never had a loader do that. Ecu failure, but normally there is a code with it and it starts up. What is it E, F, G, H
DD Cincy
Ohio
I will give it a try. I didnt notice any code come up. It flat out will not turn over!
highwayghost
Pittsburgh, PA
Emissions Analyst
Try disconnecting the battery for about 30 minutes. This often will reset the computer. While waiting, check all connections, starter and frame grounds, plug connectors, to be tight and clean. A loose connection may also be why it was 'running a little off' lately.
cuttin edge
NB Canada
Try posting more info. Year make, serial number. I can't help you mechanic wise, but if you are patient, someone should respond.
