cold weather
wally57
iowa
Good Morning
I am wondering what you snow plow operators use to lubricate the wing post in cold weather. I have a Champion 730A with a Falls wing. I have tried several things to lube the wing post but they seem to get sticky after a while and the wing sticks. Any suggestions?
Thanks
Wally
biggrader
Red River Valley of the North
Owner/Operator
I believe Falls says to use antifreeze or a light weight oil. I use JB80 and seems to work ok. You might have to apply it a couple times a day. Nothing worse than having the toe stuck up in the air!!!
smooth
SD
I put straight antifreeze in a squirt bottle and carry it in the cab. Usually need to apply a couple times a day depends on outside temp. Works good and does not build up and get all gummed up with smaller rocks and sand like oil.
wally57
iowa
I talked with the local county employees here and they said they used a JAX snow plow grease. Anyone heard of that product?
Mobiltech
Sask.
Has anyone tried dry film lubricant or spray on graphite. It doesn't get sticky but lubes well
Cat 140M AWD
Montrose S.D
Motor grader operator
I use the dry film graphite ya get in the spary cans it works great and don't collect rocks or any other debre works really good I also use it on my moldboard slides and circle
