BrianGrenier
JohnC wrote: you need to go into the electronics package and record all active and logged codes. All the Cat B series excavators used the same method to access codes. In this case you hold down three buttons at the same time till the monitor goes into access mode. Then you use certain bottoms to go to each mode. Your book should explain how all that is done...
At this time, I do not have a manual; here is my issue:
A loose oil filter caused a massive leak of all engine oil, 5w-40, shortly after an oil change.
After tightening the oil filter and draining all remaining 'old' oil, new oil was added to bring the oil up onto the stick. Starting the machine, the lights for shut down the engine and the engine oil pressure indicator were on.
Is there a need to reset the codes, or is there other advice for me?
