I'm a no-clutch kinda guy myself. Started out in a '63 B-Model Mack with a quad box, that thing was geared so low and so worn out that even with a load on, on level ground, you could have the main in 1st and just gently push the auxilary into underdrive, and it would take off like you let the clutch out.
I've had throwout bearings, clutch shafts and other things go wrong over the years and never had to worry about being stranded with the no-clutch deal. I've had to start 'em up in gear loaded a couple times to get the load off and get it home. No big deal once you've had no choice in the matter I guess.
Currently, I have a Super 10 speed (which I hate with a passion,) and I tend to shift that by taking it out of gear and "splitting",(not splitting really, but a full gear,) then sliding it back in and repeating the process. Same for downshifting, I use neutral as a substitute for the clutch. Makes a nice, smooth transition.
I could never drive a truck smoothly with the clutch, always learned to do it without it, so that's all I know. I've seen some guys who double clutch every single gear, and still manage to pull the front wheels off the ground every cog.
I judge a "good driver" :cool2 by his first 2 minutes in the seat. If he doesn't use the clutch brake to stop the countershaft and "click" it into gear, that usually is the end of the judgement right there. If he tucks it in gear by brute force or just grinding against the intertia of the gears till they mesh, he's done as well. Time to downgrade him into something a little less complicated, like an automatic.
