Clark/michagan 45b brakes
Dadam
Connecticut
I am having an issue where my loader will not go forward unless the air pressure is at or above about 100 psi. Is there a valve or some type of device that releases the brakes or allows it to go in the gear only when the air is at a certain point there is a Clark 45B with hydraulic assisted by air brakes
It goes backwards fine and when the air pressure is high enough, it goes forward fine so I do not think it's a transmission problem
