bigguyinS50
Howdy, im a new mechanic tasked with my first job of changing wear pads in the , I was wondering if there were any useful tips for going about this job or things to know, any help would be much appreciated. Thank you
Which wear pads are you changing. I've never put new wear pads in one but a have added shims to one. A lot of the time if the boom is real loose and floppy it just needs some shims. They are easy to change tho.
Btw do not go around changing wear pads hoping to cure the boom shaking and jumping when retracting. Most likely the cables need checked and tightened. Also on most of those machines the wear pads on the top and back of the outer section have never seen grease.
