Someone had posted that they thought Champion tach's run off the alternator. The tach in my recently purchased grader isn't working but there are 2 male spade connectors on the alternator and hanging down by the starter are 2 wires with female spade connectors. The female connectors aren't factory but going to the alt. makes the most sense for these wires. There isn't anywhere else they could go that is obvious. Would hooking them up on the alternator to see if the tach. works hurt anything or if even if they do go the alt., would they have to hooked up a specific way (correct polarity, etc.)? My mechanic friend thinks I should get at the back of the tach and then do some checking with a jumper wire(s) to figure out how the tach works. Thought one of the experts on here might have some insight. Engine is a 6CT-8.3 Cummins.
We did find a corroded connection and are going to replace it to get an accurate measure of volts from the alternator. Want to make sure there is is high enough volts so the transmission works properly. The bad connection arced when it was moved but the voltage on the gauge in the dash went from 12 to 12.5. Friend says having a new connector utilizing all the strands of wire could bring the voltage up even higher. Have also read the volts should be 14.3+ for the trans. to work properly but once the battery is fully charged the alt. output should be lower so the battery doesn't get overcharged. How would you maintain the 14.3 volts?
