CATT 299D XHP No Hydraulics
Well apart from the person who started this thread (who unfortunately never came back to update us on what the actual problem was on his machine) I know of no other case of a machine with no drive, implements, or fan where the cause was NOT something related to the coupling.
You need Ref #2 on the attachment.
While you have everything apart check the splined connector on the drive pump. Sometimes the bolt #3 can come loose and the connector #5 slides away from the coupler. Unsurprisingly this also results in no drive, implements, or fan.
  • 258-3318.pdf
Chrisso
Diesel Mechanic
Same here. But after hearing that, from now on I’ll keep a broken charge pump in the back of my mind next time I come across it. How good are these forums
cat262c
Hawaii
Thank you! i will keep you posted on what i find..
