Caterpillar 953C wont move when cold
Your Diagnostic Codes are as follows: -
MID030 - Cat Monitor System
MID079 - Hydrostatic Transmission Control
CID0070 FMI03 - Parking Brake Switch - Voltage above normal.
CID0137 FMI08 - Left Motor Pilot Pressure Sensor, abnormal frequency, pulse rate, or period. in other words the signal received (of whatever type) is outside the expected range.
CID0299 FMI13 - Transmission Lever Position Sensor - requires calibration (sounds likely)
CID0324 FMI05 - Action Lamp - current below normal.
I would attempt a calibration of the transmission control lever sensor first.
Welcome to the Forums jpoteat1971!:drinkup
You've got the right man to answer your questions. Nige has helped me with my BBX 953 several times.;)
Nige I found the direction and speed calibration control procedure and two other transmission control calibrations you sent me. Email sent, check you inbox jobteat.
Jpoteat, you have to make one more post before you have PM privileges. Make another one here.
