Cat336E trouble code help
ahart
Indiana
Please provide a serial number of the machine for accurate information. What access do you have to Cat ET service tool? What is the history of the machine? Original injectors? You will need Cat ET to perform the fuel system verification test for the injectors.
Cmark
The injector code is possibly unrelated. Note that it only had one occurrence three hours ago.
The derate will be caused by the 1045 code. I would start with the basic air intake system checks. Air filters, aftercooler piping, check the turbo spins etc. I once had a turbo wastegate jammed open which gave a similar issue.
Cmark
Yep, commonly associated with EGR valve issues, but in that case I would expect to see other related codes. As a standalone code, E1045 is fairly unusual in my experience.
ahart
Indiana
Correct me if I’m wrong here but once that -7 code generates, a fuel system verification test is the only way to clear it.
Another thing I’ve seen on the E1045 is soot plugging the boost pressure adapter fitting.
Cmark
Hmmm. You may be right. I don't think the logged code would cause a derate though, whereas the low boost pressure would.
Good suggestion on looking at the sensor. Either way, if there's not something obviously wrong with the air intake system, ET is going to be needed for further troubleshooting.
ahart
Indiana
Absolutely right. And if the injectors are in fact original, looking at a 6 pack. Change them all at once or one at a time. Either way, be changing all 6
Cmark
Personally I would fix whatever is causing the derate, clear the codes and let it run. If it logs more injector codes then yes, change the lot. 10K hours is getting up there.
ahart
Indiana
Another thought, if you’ve got one not performing well mechanically, you’re running the risk of doing DPF damage or worse, washing a cylinder down.
Both of those photos are of Logged Events according to the header on each screen. I’m guessing that the engine was stopped with the key in when they were taken.
I’d be interested to know whether or not they both become Active with the engine running.
partsdic
china
  1. Check for Air Leaks: Inspect the air intake system for loose or disconnected hoses, clamps, or gaskets that could allow air to enter before the turbocharger, affecting pressure.
  2. Clean Air Filter: A clogged or dirty air filter can restrict airflow. Ensure the air filter is clean and properly installed.
  3. Inspect Sensors: Check the sensors related to the intake system, like the MAP (Manifold Absolute Pressure) sensor or any associated wiring for damage or loose connections.
  4. Diagnostic Scan: Have a diagnostic scan performed by a qualified technician with specialized equipment to identify specific fault codes and pinpoint the issue accurately.
Dean F.
Princeton
Yes that is correct The key was just on not running
Dean F.
Princeton
I would suggest starting the engine, then go through the Codes/Events menu again with the engine running and see if they both become Active.
Yea I’m gonna try that when I get back to the house, I went and picked up a reman injector, quill, and valve cover gasket this morning it was a sh*t show to get the right one from cat, had to drive 2.5 hours outside of town to pick them up yesterday! ‍♂️‍♂️
Dean F.
Princeton
Ok so, got injector swapped out, regen was at 76% now it’s at 95% and won’t auto regen
Cmark
So do you now have any active fault codes or events with the engine running?
You bought a reman injector on the basis of one logged fault code that occurred three hours ago?
