r20d12
- Joined
- Nov 29, 2009
- Messages
- 123
- Location
- oklahoma
- Occupation
- heavy equipment field tech since July 1990
That is great that its fixed!Sooo it was all related to the ground for prv solenoid. The wiring all goes though the pump switch for auto and manual. Someone had ground wires reversed and one had a bad connection. I checked ground at prv somewhere In process it read under 10 ohms but it had a weak connection. Weird part was the display for prv value was dropping to zero like it was seeing low rpm. As soon as I swapped the two grounds on switch and fixed the bad connection the little red lights on monitor went out and prv started working right. Wish I had more time to dig into why and how it worked but had another machine to tend to. Thanks for the help was getting ready to throw parts at it.... Glad I asked on here. I've had some really tricky ground issues lately had one I posted on here about on a 3056e. Took three years dam thing ohmed out fine but when cranking shot over 100 ohms I thought it was a voltage issue because boosting power helped. Thanks again love the ideas and even the ones that seem off base I'll be doing something else and be like that's what they meant.
The hardest ones are those that someone else "fixed" before you got there.
