Thanks that is very similar to what I recall but they just pushed in and had a plate on top to hold it in. Now to me it seems the orifice has blown out of the old one. I was concerned the orifice was clogged. Now if the part blown out is the orifice the trans should hard shift(snap into gear fast and jerk you in the seat) If you still are running on initial pressure some debris from the old orifice is clogging up the passage from the orifice to the load piston. The load piston is on the opposite end of the spring as the modulating relief valve is and after a shift clutches fill to initial pressure as yours does now. Oil pressure then comes through the orifice that controls the time of clutch fill and clutch building to full pressure.
Later Bob
Later Bob
