hi guys having a problem with my d8 its completely lost steering in both directions!
serial 5tj-01036
went out to work last week, was perfect no problems,10 mins into work and boom no steer.
did some pressure testing on the circuit and got only 400 psi on the steer motor(which im guessing is charge pump/lubracating pressure),so got the hydraulic pump out and changed the barrel,pistons etc. put the pump back in but zero difference,also opened and checked the motor but it looks like its in great shape so put it back and still no steer.
tiller and pilot pressure also checked im getting 300 psi there,pilot pressure is actually reaching the hydraulic pump but the pump is not stroking.trying to find out the problem i also took the actuator neutral adjustment about 2 turns out to see if the machine would steer in that direction and yes it worked.
would really appreciate if anyone could help me figure out why the actuator is not making the pump to stroke.
serial 5tj-01036
