Old Magnet
Those look like Vickers part numbers but they don't match up to either the 7J4634 or 9J5058 pump.
I finally got time to pull the floor plates and ck the hydraulic pump for numbers. There were (4) #'s visible; 2720171, 2884865, 2919651, 2967488. I was expecting a single part #.
Using 3P-1198 as the Arrangement Number leads me to a 7J-0612 Pump Gp. There are 2 types of 7J-0612 Pump - Type 1 & Type 2.The triple valve arrangement for the 8S, 8U with tilt and adjustable 8D ripper originally is a #8S8666 and is replaced by arrangement #3P1198. Hopefully you can find some numbers on the pump to verify what you have but most likely you will be dealing with the replacement arrangement.
Type 1 pump uses a 7J-0573 38gpm cartridge + a 7J-0581 14gpm cartridge.
Type 2 pump uses a 7J-0573 38gpm cartridge + a 7J-7967 14gpm cartridge.
7J-0612 as a complete unit services to 9J-5050 Pump Gp or 422-8168 Classic Pump Gp.
This is all based on the assumption that the pump that is actually in the tractor is the one that's supposed to be in it according to the Parts Manual...........
