Just a thought,
Based on my experience i never seen a main bearing set failed in a diesel engine due to lubrication issues, (unless it was due to contamination) Main Rods bearings yes, Hoo yes , usually they throw rod´s out of the block if u hear them knock and insist on running them.
Recently i had my Mercedes OM606, with this type of problem, engine oil was going up instead of going dwn, replaced lift pump plunguer seal (more or less same system as CAT) and its fine now. I do not plan to look at the Crank mains or Rod bearings.
If u wan´t to go that road, its a precaution, but look also the main rods, thats is where the system is weaker.
regards
regards
