Cat d6d broken track spring advice
mlaird37
Tx
Need some advice on this one. While cleaning the dozer I noticed the track spring has 1 coil sheared in half. Track is still tight and adjusts just fine. I only plan to use this machine 100-200hrs per year. It’s going in the shop to get new sprockets and replace a missing roller on the same side. I know replacing the spring is a huge job. Should I have it replaced while it’s in the shop or just operate as is since there are no issues with the track loosening.
Kinda hard to see in the pics but it is a diagonal shear all the way through the coil.
A busted recoil spring could easily cause a track to derail.
Search for "Death Spring" before you start disassembling. That spring is not to be trifled with.
Post a Serial Number and i can find the parts listing for the recoil mechanism. Both OEM and aftermarket springs are generally readily available.
mlaird37
Tx
Thanks. Stamped 4x4494 but may be 4x004494
JD955SC
The South
What I know about death springs:
1- Cut them with a torch
2- Let the shop idiot put the new one in. Also doesn’t hurt to let him do #1. I’m too smart and valuable to die doing something that stupid- he’s expendable.
TomA
Mariposa, CA
You can probably get by just fine for a while. When it is in the shop is a good time to get everything fixed properly. It takes a massive press to install a new spring. Not work for an idiot.
