yeah scrub, too many people think diggers and trucks is only way to move dirt. Tractor and scoop is 'old' technology. Is is but it still works and works well too on shorter hauls. In my case 100-500m. As long as I can get ontop of and behind the dirt, its just 1 man and 1 machine, load, carry, dump, spread, trample, return and start again.
Digger and truck has there place, but not do all and end all of dirtwork. Each one depends on the other to move dirt. Digger or truck breaks down, things stop. 2 scrapers, don't matter if 1 breaks down, other one keeps working.
Forgot; I did see one setup on a late D85 with a 15SBW kokudo hyd scoop that seemed to work ok. A towing hitch was fabricated and mounted midway underneath the lower centre ripper linkage. Had 4 barrel rippers and with linkage right up and tilted forward and all picks removed, the point of connection was pretty good and wouldn,t create too much thrust when turning.
Is still quite a few D8H/Ks running around NZ with both cable and hyd scoops. And a a lot of D7H/D85 with the 15 kokudo scoops, on swampy or standard shoes too.
