Scrub Puller
Yair . . . Guday Cam85! Good to see you back? Wotcha upta?
We knew them as a PCU Power Control Unit . . . the folks in The UK and US seem to use the terms CCU Cable Control Unit or CPU Cable Power Unit.
On the back they are usually two drum. The right drum is used for blade lift and, when hooked to the scoop runs the hoist, the left drum runs the eject and the apron.
Don't understand your hi-falutin terminology . . . I work in cubic meters of excavation.
You need to compare apples with apples and would need to know tank details, distance to wings, and hourly rates before any comparison could be made.
The point is that a scraper alone is a bit limited . . . you need a dozer to clear the site and clean up.
I haven't seen a scoop behind a steeltrack in a long time but there was an outfit in the US with a heap of D11's and 52yard scoops up until the financial crash . . . apparently they reckoned there was no cheaper way to move dirt up to a thousand feet.
Google McAninch on Youtube.
Cheers.
Cheers.
