Cat d6c 10k final drive support seal
keith-50
Elgin,TX
I was going to adjust final drive bearings with spanner wrench and noticed spring wire coming from support assembly on left final drive seal. Removed outer support assembly. Service manual mentions seal and Bearing in outer support assembly. Found portion of seal but no bearing. Is bearing mentioned in service manual really a bushing?
Master Link
Dallas
Heavy Equipment repair
It's not fiber. It looks like a giant cam bearing if you know what one of those look like. 5M6637 is the correct part number. 4S6752 is the seal that goes in the housing with the bushing. That's probably where the spring came from as there is one in the seal.
keith-50
Elgin,TX
finally received my support bushings and seals for final drive support, Is there an easy to install those giant bushings, with out damanging them, thanks
Dave Neubert
Monroe NC
best way is to press them in with a shop press but I have used a piece of heavy plate steel and a heavy hammer don't hit the bushing directly except to get it started
