Cat D6 A/C
Tenwheeler
Georgia
????00D6FUFBH0260 Has about 100 Lbs freon charge and appears compressor will not engage. All of the fuses and breakers at the right door hinge ares test good.
Air flow in the cab is good.
Snow flake on the A/C switch lights up when depressed.
Pressure switch behind compressor has power on both sides.
Two other two wire connectors, below the alternator, show no power with a probe at the back of the connectors. They are hard to get to and would have to remove the alternator to possibly unplug and test them better.
Wondering if there are some relays and such somewhere? Anyone have a wiring diagram for this machine?
Thanks for any help available.
nowing75
coatesville indiana
i was not able to pull up that s/n
heymccall
Western Pennsylvania
Wrong serial number, but relay location is same, in this thread...
Tenwheeler
Georgia
02601 in the door jam. Thanks.
Found 2 relays on the right side of the seat under a control panel. Both have power all the time. No other power with key on and turning on A/C. Swapped relays, compressor still did not come on.
OK, so the S/N is FBH02601. The "1" is partially obscured by a scratch on the plate.
In this case the correct number is really important because there are no less than 4 different schematics depending on S/N.
Schematic on the way. Check your messages.
