truecountry
loaned it out to a company we do a lot of work for ..call came in broke a hydraulic hose they fixed it washed machine off now it will not start blows fuse...
I go check machine find a short to ground.. wire 308 from key switch to ecm replace wire outside harness for a quick fix till I can tear machine apart and replace the harness ...Now I got another problem that must have happened at same time ...no lights on dash panel and machine will not move so I check fuses power to 1 - 10 ..no power 11 -20 hmmmmmmm what powers this I call cat find relay behind fuse panel power one side no power other side ..ordered part …
My question or wondering wtf happened to cause engine cranking and powertrain problem at the same time ?
Broken wire is under floor near dash ...ive looked at wiring diagram cant see were 308 in harness is near power to relay in fuse panel ..am I missing something
Or am I over thinking problem ? AGG0655 is machine serial number
