I'm getting codes 691-7 692-7 693-7 695-7 the transmission will go thought and calibrate every time the clutch pressures are in spec has new filter and screen is clean. I still need to check priority and supply pressures but I'm currently leaning to them being ok as the trans pump is fairly new. There is no speed sensor codes. Every time it shifts it will code out. 6as prefix. Any ideas thanks
