7379df
Was working at low idle... went to raise blade and nothing happened. Then the alarm sounded and machine stopped. No hydraulics. Hyd Oil level is good and oil has always looked clean. Can a pump just all of a sudden go out ? Wasnt even working it hard whatsoever. Like I said... throttle was set a 1400 rpms... just skimming the ground to get rid of brush.
So my thoughts are this.... either its mechanical and the pump just went out in the snap of your fingers... which i find really crazy.....or electrical sensor issues.
My next step would be to verify via. gauges that pump is working. Not sure what ports I need to tap into. Im assuming the ones by the filter but there are two and not sure what quick connect i need for them. Any help would be appreciated.
