Coy Lancaster
Hey guys I'm needing the torque specs for a 3046t engine in a Cat D5G if any one has any information please let me know.
Yes the head bolt and rod bolt torque, thank you.Torque specs as regards threaded fasteners or the engine torque..?
Good day Nige if you can would you send me the valve adjustment and sequence for this 3046 Cat engine please, thank you in advance.Connecting rod bolts
Before assembly, put engine oil on the bolt threads and all surfaces that make contact between the bolt and connecting rod caps.
Torque for the connecting rod nuts ... 54 ± 5 N·m (40 ± 4 lb ft)
