Cat D4XL AC help
Dustin Sayer
texas
I have replaced orifice tube, drier, cleaned out evaporator and condenser. new filters vacuumed out system and new refringent still cant get the vent temp to go below 60 degrees
ahart
Indiana
Dustin-
Would be more than happy to advise, please respond with the following information.
-Machine serial number prefix
-AC pressures (high side and low side) at idle and high idle
-Ambient air temperature
-A little bit of history leading up to this issue
-How much R134a was put in the system during recharge
Dustin Sayer
texas
Dustin-
Hello and thank you. the ser number prefix is kmm
low side pressure is 50 at idle high side is 250. I have not checked at high idle
ambient temp 90 degrees
the ac would blow cold in the morning when the ambient temp is around 70 degrees, but once it got past 80 outside the vent temp would be lucky to get below 70, so i put new filters in cleaned the condenser and evaporator. Both fans are working, Compressor is working and still the same results. So I replaced the drier and orifice tube, vacuum out the system and added 3lbs of freon. Now vent temp is a consistent 60 degrees so it's a bit better but I checked vent temp of our other machine's (one being same model and year dozer) all are blowing between 40 and 45 degrees out the vent
ahart
Indiana
I don’t believe they are heater valves on your engine. You can clamp off one of the hoses to stop any flow going to the heater core.
I really have nothing to offer in this discussion except it makes a big difference in the A/C with the heater valves off on our D5G and 953C. Sometimes I'll forget to turn the valves off when the weather turns warm and think we have an A/C problem.
heymccall
Western Pennsylvania
I, personally, think the charge level is too high.
I just replaced a compressor on a 314ELCR, and the machine sticker for charge amount was different than the book. The book was higher.
I'd like to see no more than 40 psi on the low side, at idle, on an 80° day. At fast idle, when I don't have a charge spec, I try to make sure it doesn't drop below 25psi on the low side.
All of my late model Cats do have a charge amount sticker somewhere on them.
Any chance of throwing the gauges on the twin machine you have?
As ahart mentioned above there are no heater shutoff valves I can see on your machine, just two spigots for the heater line connections. See illustrations below. however I suggest that you check those locations physically just to make certain.
However as a test why not try crimping one or other of the heater lines from the connections at the engine to the cab using a pair of vice grips. That will stop the flow of hot coolant from the engine totally. If the A/C then performs correctly you should start looking at the operation of the electric heater valve located in the heater assembly as mentioned by Mark250 in Post #7 above.
ahart
Indiana
I agree heymccall, I think 250 psi on high side is excessive, needs to be closer to 180. If you get the high side down, the low side will probably follow.
1466IH
prairie du rocher, il
Does that machine have the condenser on back of cab like a track loader. Have seen lots of 953,63, & 73's with bad fans cause lots of issues.
