As The Wrench Turns
I will post photos when I reassemble. Nige, do you have the parts listing for the resonator valve, my parts book does not show that valve.
I do not know if that is a welded converter or not. It is recommended to replace a welded converter after a clutch failure like that. Have drilled a hole and threaded for an 1/8 inch pipe plug. Then pressure washed the heck out of them. Would never do that with a machine that parts cost so much and are so labor intensive.Yes, this will be great help. Thanks Nige
