SimpleFarmer
My D4H Caterpillar runs great for about 30 minutes and then it begins to act like it is running out of fuel. The last time I tried to use it I let it run for one hour then started my work. 30 minutes later I had to shut it down because it was missing and would only run at 50% power or less. If the throttle was increased, it made no difference. No change in the engine sound. I have loosened the fuel linkage at the ?fuel distribution block? Before it goes to the cylinders and fuel is present, no air (my D4H does not have a hand pump to purge air and pressurize the fuel line). I have looked for a fuel filter but have not found one. I am looking for a filter about the size of a soup can, that is what is on my IH tractor.
Does anyone have some clue as to what is happening to my baby? Can there be water in the lines? Seems like that should keep it from running altogether. Thanks.
These are all the numbers that I have found.
Caterpillar D4H Dozer
1986?
Ser num. 8pb01884
45v66228
--------2431
Holt tag on back
W/O. 0115330
S/N. 1CE0236p
Caterpillar tag near seat
D4H
3204DI*8PB01884
45V66228
1CE02431
1986?
Ser num. 8pb01884
45v66228
--------2431
Holt tag on back
W/O. 0115330
S/N. 1CE0236p
D4H
3204DI*8PB01884
45V66228
1CE02431
