CaptainB
So I changed the hydraulic hoses of the old d4d and everything was fine for 15 minutes then the rod of the hydraulic cylinder left side got separated from where it’s supposed to be screwd into pics:
I measured the cylinder but I’m not sure about the length of the rod and I think this rod was welded “Mexican style” by the previous owner so I bet I’ll need to take that metal bracket where the rod screws into to the shop for rethreading
Also I’m thinking I’ll need to buy a hydraulic cylinder repair kit with all the gaskets etc needed not sure which one to buy either
Finally I’m thinking maybe I should do both sides to make sure both rods are same size, before this happened one rod was probably longer than the other the blade being always higher On the right side than the left which made uprooting trers shrubs etc more difficult
Would appreciate any comments advice etc thanks
Jose
Jose
