I meant to say I have the service and ops manuals.Okay I’ll probably get a hard copy then. I have the other two (service/overhaul) which were a must for sure. Thanks.
That doesn't surprise me. Back in the day the service & parts manuals for the engine were generally separate from the machine.
Well I did get a parts manual coming. It was long needed.That was usually because the same basic engine was used in multiple applications
Wow I just saw your recent Video on the first start. Incredible and excellent jobI saw the fuel line leak which you and I both had. Too funny. I’ll hopefully have my first successful start next Wednesday. It will be most likely be my last trip until May. It’s going to be a long winter. I’m going to tarp it up and mothball it the best I can. If all goes well have it hopefully moving in June.Lol, I just had that same exact issue with that little ring missing on my injection pump and the line leaking. Fortunately I found one off a spare line that broke into 3 pieces, but I stuck it around the line with some grease and it sealed up.
If I had to make up a new one, I'd look at the hardware store or at McMaster for a spacer where the inside diameter matches and cut it in half to get it on the line. Others here might have a better idea though. Sounds like you are close!
Yes it will be, but not much choice due to where I’m located and where it’s located.Good luck! Looked like you were pretty close to get it running in that video you posted. Gonna be a long wait to June
I just see them now on the desktop? I have one more short one with it running smooth. I will keep trying.Thanks I’ll take it. I’m thinking a C- for my videos! Not sure why they are not available? They were for a short time. Plus for some reason I can’t get the third one posted.
Wow, sounds good enough to make a person think it was running strong just yesterday, Have you tried to move it or anything under it's own power yet?so here is my clip I can't embed?? any ideas?
https://youtube.com/shorts/45na886l25c
