Kyle Carson
I'm working on a D3C series II, 4HJ, that doesn't want to steer to one side. The left pedal will work perfectly...clutch disengages and the brake works smooth and easy for a left turn.
The right pedal is much harder to depress and when it is fully applied the machine comes to a stop. If more throttle is applied, say 50%, then it will go ahead and turn right. I have checked the slave cyl pressure on both sides and they are both the same, 360psi. I don't understand why the left track will not push the machine to right until it gets more fuel, and the fact that it will go ahead and work tells me that the left clutch is still in working order. Thanks for looking at this, any help is appreciated.
