Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
Get hold of someone with Cat ET software, connect to the ECM and pull the Diagnostic Codes & Events. That will tell you why the engine is shutting down. You're batting in the dark until you get that information.
You should be able to pull codes by shutting off cruise and holding set and resume switch one way or another with key switch on. Should flash check engine light, count flashes, should be a 2 number code. Dealership should be able to tell you what code means. 55 means no codes stored. As close as you can get with out ET.
Code 24 is oil pressure sensor voltage high or low. Depending on serial number should be on right side under turbo. Check wiring harness for rubbed wire if dont find anything try a sensor. Hope this helps.
