Cat 980G Series I Fluid Capacities
vf949
Ireland
Does anyone know where I can get a list of the fluid capacities on a Cat 980G Series I ?
Serial no range is 9CM373-2141.
Thanks!
Approximate Refill Capacities - note only approximate. Use dipsticks and or level plugs as appropriate and fill to them rather than putting in "X" gallons.
Component or System Liters US gal
Cooling System 83 22
Fuel Tank 470 122
Engine Crankcase 34 9
Transmission 62 16.4
Hydraulic Tank 125 33
Front Differential and Final Drive 87 23
Rear Differential and Final Drive 87 23
vf949
Ireland
Hey Nige thanks very much for that information!
Is that from an operators manual?
Thanks.
>HevyIndsMFGng<
Oshkosh, Wis
Mechanic/Student
A CAT or CAT Dealer employee has many sources to get this information off of, but that info would definitely be in an Operation and Maintenance Manual.
vf949
Ireland
Okay cheers folks. I don't have access to an operators manual for this machine at present so thanks for your prompt responses.
