Len220
I have a Caterpillar 973, serial number 86G032XX, 07/97 in NSW, Australia. It is the second series of machines made in France. The previous owner had it sitting in a quarry for many years after a mechanic adjusted/serviced the hydrostatic transmission. They reversed up the machine and then it wouldn't go forward. It sat there for 5-10 years. A few people have had a go fixing it, to no avail. I picked it up for a bargain as the owner has lost interest. I want to bring it home and sort out the hydrostatic transmission. The motor runs okay and the implements and associated hydraulic pump works okay (except for some burst perished hoses).
At the time I didn't realise that the hydrostatic transmission had been drained (to use the oil elsewhere), but I only ran the engine for a few minutes to see how it sounded. Reading the owners manual, it appears I'll have to get the brakes off to move it onto a loader and get it home. I understand this can be done in 2 ways: by pressurising the hydraulic lines to the brakes, typically from the distributing manifold (on the left side of the machine ?) with a hand pump; OR taking the centre shaft out of the final drive sun gears.
My question is: can I take a simple hydraulic pump like a portable-power pump and attach it to the hydraulic lines to disengage the brakes? What sort of oil volume will I need to pump, to get both the brakes off ? I plan to put oil back in the hydrostatic transmission - Caltex Delo Gold Ultra - a multigrade 15W-40 oil, same as the engine, recommended for the 86G3000 and up. It'll be working in 10° - 40°C temps.
However can I get the brakes off by pumping oil into the brake lines regardless of the hydrostatic oil status - drained or otherwise ? What volume will the brakes (and the supply lines) take before they are disengaged ?
I'm hoping Bob/Ont and you other experienced CAT 973 guys, will pick this up quick.
