Andrewk143
My 962m has came up e1389 fault code and 3609-12 fault code and is now in limp mode tried changing the nox sensor and still no good, any help would be appreciated
To clarify. Are you referring to the E1389(3) Event or the 3609-12 Diagnostic Code for the NOx sensor - or in fact both.?You will need to run an aftertreatment system functional test with ET to prove to the EPA that you have successfully repaired the problem. Once that test has completed successfully, the fault will go away on its own and you can resume normal operation.
Hi nige hope you are well, is there and possibility you could send a pdf over for fault code 3609-11 on the same machine please3609-12 "Aftertreatment #1 Outlet #1 NOx Level Sensor : Failure.
Troubleshooting, "Sensor (Data Link Type) - Test"
Here's the troubleshooting procedure.
E1389 Operator Aftertreatment Inducement is related to the 3609 but with it being Level 3 I fear that now the machine is in limp mode the ECM will reqiure a reset with a dealer version of ET.
