Ashton Cooke
i will check once more and report back. thanks
test port g = give or take 390 psi close to 400..... i understand that p2 is the direction clutch . but i **** you not i have 0 psi but the machine moves foward.Refer back to the test procedure page 5. Put a test gauge on port marked G that is located on the transmission filter housing and measures pump pressure. See what that gives you. Note all these readings should be done with the oil warm.
Maybe start by draining the oil and remove the suction screen to check it.? That is if you haven’t been in there already.Okay here is the valve body also when I went out to take this picture I started the machine with guage in test port g . This time guage reads 50- 80 psi . No clue why I got over 300 psi before . But now machine Has been running for an hour and Gage won’t go above 80 psi
