svcman717
Need help finding a Rear main crankshaft bearing for a D320 engine. Cat part # is 7M9283. Aftermarket bearing would be fine also.
You better check your part number ,I've never seen Cat use the same number on different size bearings.Thanks. I saw the one on ebay but I need a standard bearing. I'll call Regal tomorrow. Thanks again. I guess if worse comes to worse I could get the .020 under from ebay and get the crank turned. These engines are kinda rare (D320) and some what hard to get parts for.
