Don t know where you are.carter cat in Salem va at one time had a field full of older parts might look them up give em a callI believe its a 1958.
I need a top carrier roller. Early bronze bushing style.
Transfer fuel pump repair kit.
Some track pads and a skid plate.
Immediately need roller and pump kit (diaphram leaks fuel from relief tube)
Any help is appreciated.
I live south of Boston, Massachusetts. I keep it at my camp in Maine. Use it in the woods to clear a few hours here and there. I have the complete serial number if needed. Caterpillar dealer said the roller is obsolete. Does anyone rebuild them? I believe I've covered all your questions. If not ask away. Thank you.First question, Serial Number and yes I see 11A? Parts are dependent most especially on Cat by whole S/N. Second, as noted Where are you at as are plenty of yards and suppliers but pertinent to states? Lastly what is machine use, Hobby: couple hours here and there, significant farm duty, secondary equipment for a contractor?
All are pertinent, used parts will usually end up as bad or worse than already have many needing reman before can actually use, blind bought 933 parts may net you NON Functional to s/n series and lastly for a Hobby machine Cat Classic parts are as close to what a yard will cost you used for new parts.
What Part Number roller were you looking for.?I live south of Boston, Massachusetts. I keep it at my camp in Maine. Use it in the woods to clear a few hours here and there. I have the complete serial number if needed. Caterpillar dealer said the roller is obsolete. Does anyone rebuild them? I believe I've covered all your questions. If not ask away. Thank you.
