Cat 931b right steering issue
msllc
MID-ATLANTIC = VA
Hey guys. Hoping you can help me sort a strange a couple of issues out. I just bought this machine a week ago. Was using it when I noticed the right side track would come to an immediate stop & “bangs” loudly when trying to steer with right pedal. The middle brake is basically all stop, not much in the way of “feathering” to a stop. Pretty sure the Serial number is 25Y01728. Definitely sure it starts with a 25Y, though. I have yet to open up the floor to check for obvious problems or check any fluid levels. Any help is greatly appreciated. Thx.
msllc
MID-ATLANTIC = VA
These are the best pictures I have of the machine right now. In case it is needed to help establish what year it was made.
That does look like a good S/N SIS shows this:
931B TRACK LOADER
Machine Serial Number - 25Y01728 (Build Date - 14/11/1982)
Note that Cat build date format is day/month/year
I have access to SIS but no direct knowledge of most track machines so hope someone else can chime in.
If you need a systems operation or other information I might be able to access that much.
Just on the chance the last owner left it in there check behind the seat to see if there is a owners manual in a pouch there.
msllc
MID-ATLANTIC = VA
Ok. Will try to get that done very soon. Was just working on it yesterday replacing the sand trap / air intake pre-cleaner & both engine air intake filters too. Will check all fluids once I get back out to where it is. Thx guys.
Check the rollers on the steering clutch actuators. It could be the steering clutches aren't completely releasing and causing the brake to grab while still trying to go forward.
Just to clarify on Old Magnets post, tighten the brake bands up and then adjust the linkage as tight as possible while still being able to put the pin in the yoke. Then back the brakes off 1-1/2 turns and that assures the free play is in the brake bands and not the linkage. I think there should be about 3"-3 1/2" free play at the pedal. Bob/Ont told me that several years ago and it's fool proof. You read the Cat manual and you have measure the length of every rod in the linkage. Bob was the expert on these machines and is sorely missed. I have 25Y01916.
msllc
MID-ATLANTIC = VA
I'm hoping to be able to get out to the loader again very soon. As soon as I do, I will be certain to adjust these brakes. I should probably ask where these adjustments are before I go on a wild goose chase thinking I know where to be looking for them. Are they located back beneath the battery? Or, located just below the floor plates?
Old Magnet
Corralitos, California
On early s/n's the brake adjuster is under the small cover plate just ahead of the lever housings on the cover plates. If it has the oil clutch/brake option the adjuster started out below the cover plates then changed to protrudes above the cover plates.
There are bolts on the bottom of the machine to hold the brake bands up if it has dry clutches. The adjusters are under diamond shape covers beside the seat. I think some machines had extensions sticking up but likely under the covers and you need a socket and extension. I can't remember the size though, Spray the adjusters good with penetrating oil as they could be rusty or stiff.
msllc
MID-ATLANTIC = VA
I was able to look under the machine on Saturday. I did NOT see any bolts from the underside going into the steer clutch areas. I did see fill plugs for each steer clutch housing & fill plugs for final dives too. I did find three drain plugs for the bevel gear & steer clutches on the bottom of the machine too. I was NOT able to actually work in the machine though. I will try to ad just the brakes & remove floor plates soon to give more feedback.
msllc
MID-ATLANTIC = VA
931B TRACK LOADER
I did NOT find an operators manual left on the machine. I am guessing that would be quite rare.
I think it's fairly rare to have wet brakes on an earlier machine but could be. Look in the archives on here Wosama031B has wet brakes on his 931B.
Typo, that should say Wosama931B. The bolts to hold the brake bands up on dry clutches have a pipe around them to protect them and could possibly be packed with dirt. If you do have wet brakes you have to be really careful you don't adjust them too tight or the brake bands will chew into the drums. Bob/Ont has posted about about it in the past.
msllc
MID-ATLANTIC = VA
View attachment 195701 This is what you'd be looking for if it has dry brakes (support screw)
Oil type steering clutch and brakes would have been available as an attachment.
I don’t remember seeing anything like that so near the final drive drain plug. I will try to take a good picture of what is on the bottom of my machine. From what that picture shows. It would seem as though areas would get damaged quite easily if running over concrete of larger debris. The drain plugs I did find were towards the very rear of the machine, within 8 - 8 inches, or so. I would also assume that a wet steer clutch would be far better from a wear perspective as well. How clean / what color should this oil / fluid look, if everything is in good shape? Honey golden? Clear?
Old Magnet
If it has dry steering clutches there will be five shielded items all in a row. Center drain plug for bevel gear compartment and one each side for steering clutch drain, the other two being shields for the brake band support screws. From your description machine may have oil clutches. Oil could be as you state, just not black or have water mixed in.
I misstated on the brake adjustment. If it has the brake band support screw tighten until the band just touches the drum then back off 1-1/2 turns. For the brake adjustment turn until tight then back off 3-1/2 turns. Brake pedal free travel should be 5 to 6 inches.
wosama931b
Fayetteville, NC
Real Estate Broker/ Ret.
Hello, when i start my old 931b, give a few minutes to warm up ,then i go straight forward and back a couple times to get the fluid moving, and even with the new track will be stiff. Also you may need a few rpm to get the pressure up enough. Also get to know your machine, look very closely at everything. Take photo before removing parts.
You probably know all now. Good luck
msllc
MID-ATLANTIC = VA
UPDATE: ok so this took a long time to get around to, but I did pull up the deck plates. I checked both steering valves for the little roller being present. I did not find anything obviously bad or missing from either steering valve. I suppose the next step is either taking hyd pressure readings or just rebuilding the steering valve for right side. I did verify that this machine still steers HARD when steering right, but does not do it when steering left. Tried to determine if left pedal goes any further forward than the right pedal does, they seem to travel the same amount. I'm pretty sure the brakes are adjusted equally, I will have to revisit the machine to see if there are any brake adjustment bolts under the rear of the machine very soon. Any further thoughts in the mean time?
