Cat 931
Ghunt
Renfrew ontario
Hi recently purchased a 78 931 track loader. I have oil seeping out of the right pressure test port and spraying out of the left when trying to turn left. Issue I have is they appear to be bloke. A someone help me with what should be there I will post a pic.
Tyler d4c
Salix Pa
There's plugs in there so when you repair or install the clutch accuating cylinders you can Bleed the air. You need some new plugs
Ghunt
Renfrew ontario
Tyler d4c thanks for the reply. Machine works well other than this issue. It’s losing pressure I assume…once I fix these plugs it should pull itself around better.
Are they literally just a bleed plug
Tyler d4c
Salix Pa
No it will make no difference in the machines performance there is pressure there only when the clutch is released may help if you top up your transmission oil
Ghunt
Renfrew ontario
Ok great thanks again. Any chance you know what one of those look like or possibly have a schematic of the part? I have a parts book for it just looking through it now.not finding anything tho.. I will have to try and get the broken ones out. Just like to know what the piece looks like.
