That's kind of along the lines I'm thinking. What would the preferred method of "unsticking" the engine be?
As bam1968 says first thing to check is oil level to see if there is coolant in there. Might want to crack open the drain and let a little drip out, if there is coolant in there it should be obvious as it will be at the bottom.
If no coolant in oil pan next to check would be the cylinders. Take fuel lines off and remove the nozzles, believe it takes a 15/16 or 1 inch socket on the top of prechamber to get them out a 3/4 inch wrench to remove the fuel lines. Once the nut is off the nozzles should pull out with the adapter. Once all them are out try turning engine over to see if anything comes out. I would suggest covering the fittings on the injection pump the fuel lines come off to keep dirt and crap out of the pump!
If it won't turn I think I might begin by dumping some penetrating oil in each cylinder through the hole the nozzle can out of and let it set for a couple days. Then with the nozzles still out try turning it over. If you can get good access to the front of crank try turning in both directions.
If you need a better description of any of this let me know and I can try for more details or even pictures!
