So basically I stopped for 30mins, started my Cat, and the gearbox oil temperature started jumping out of nowhere. I think it's the sensor, just I don't know where it's located to change it. If someone would send a manual, it would help out a lot.
It's far more likely to be a wiring/connector fault if the gauge in the cab is jumping.think it's the sensor, just I don't know where it's located to change it.
If the wiring/connector fault would occur, wouldn't it start jumping from 0 to the normal temperature instead of the maximum?It's far more likely to be a wiring/connector fault if the gauge in the cab is jumping.
Looking at the Diagnostic Codes might provide some insight.
To identify the sensor location and an electrical schematic requires the Serial Number.
