justsomedude
Hello all. Hoping for a bit of guidance here as im no expert
I have a Cat 420eit (SN: DAN00662) one of the stabilizer legs wont go down. It is currently up all the way. i have noticed some things that lead me to believe it is something to do with the valve in the valve bank at the rear of the machine.
Observations:
1. the lines from the valve bank to the non working cylinder get warm from just idling the tractor. the lines to the working stabilizer are cold. Pilot lines going to the valve also stay cold
2. there is a sound that sounds like flow is happening without the control being touched.
3. moving the control to put the leg down produces no sound or movement.
3 moving the control to pull the leg up produces sound like the pump is working but no movement (leg is all the way up).
4. i swapped the pilot lines going to the valve bank to see if any changes would happen.
the sounds listed in observation 3 swapped to the other control direction but no movement on the cylinder.
Any idea what i might be looking at or suggestions to look at / try ?
Observations:
