justsomedude
2010 Cat420Eit DAN00662
Charge light on / no tach / battery voltage only
I replaced the alternator but it seems like its not charging / no tach. with the key on motor off the exciter post reads 2.6v.
I touched a wire from the battery to this post with the motor running and the charge light went off and tach started to work until i removed the wire so I'm assuming it really wants 12v. I'm seeing all sorts of conflicting answers about what voltage this exciter wire should read and at what time. Maybe its machine dependent? From looking at the schematic i see that there is some kind of resistor that plugs in somewhere on the harness but the parts manual does not show a call out for it so i have no idea where that is or if it could be my problem. If someone could point me in the correct direction on if exciter voltage is supposed to be 12v or 2.6v and / or where this resistor is hiding out i would appreciate it.
